Indexing plate vs dividing head
Well, if you could have started from round stock, then the whole thing could have done pretty quickly on the lathe, in one setup, other than the notches in the O.D. Then the notches could have been done easily in a chuck mounted on the rotary table, or in a spindex.
Yes, I wish I could have started with round stock, but I didn't have anything big enough. In retrospect, it might have been more time-efficient to have driven the 60 miles to MacMaster-Carr and bought a piece of round stock.
I bought my rotary table from a guy I met recently. It is very accurate, and I've used it on several occasions with good results. What I'd like an education on is given the material I was using, is there a more efficient way to accomplish what I did? What tool (if any) that you listed could have streamlined THAT process? Other than the rotary table and the collet block, I've never used any of those, so they're a mystery to me.
Any wise counsel would be much appreciated.
Regards,
Terry
Quick follow up to my just-posted reply:
If you had to make this part in your shop with the same material I used but with your tooling, how would you have done it?
Regards,
Terry
Regards,
Terry
I really do not know what I would have done differently besides starting with more suitable stock in the beginning. I would not have driven the 60 miles, but would have waited for it to be delivered.
  • Like
Reactions: tjb
Actually, that would be 120 miles. It's 60 one way. It sounds like my most fundamental 'rookie error' was trying to think of a nifty way to use a piece of scrap without throwing it out. I must disagree with you in one respect, however: I can think of a distinct advantage to the round trip drive. It would have significantly eliminated the state of agitation I contracted from plowing through this project. Now that it's over, I'm glad I did it, but no way will I do it that way again. Live and learn.
Thanks for reviewing my approach. It was helpful.
Regards,
Terry
Regards,
Terry
I guess what i meant to say is that I would have simply waited until I got more suitable stock. It did not sound like you were in a huge rush to get this project done because it was holding something else up where you needed it. I would never throw away a piece of leftover material bigger than chips...
  • Like
Reactions: tjb
Yeah, but see, you're a seasoned machinist. I'm like a kid with a new toy!
Regards
P.S.: What do you have against chips?
