I find that trying to understand every single variable in motor/drive terminology has rendered me senseless. As Jim wrote, it's confusing. What I've done - in my mind - is categorize the motors (likely used in hobby CNC applications) to types with
significant differences.
1. Stepper (permanent magnets, lots of poles, used for non-feedback positioning in most cases, low max RPM)
2. Induction (typical 1 or 3phase motor driving spindles and so forth. Big drill press kind of thing)
3. BLDC (permanent magnet, windings energized with DC at highish voltage, commutated using hall effect sensors, not used for positioning. Higher RPM and greater power density per weight or volume than Induction or stepper)
4. Servos
4A. DC servos (brushed DC motor with encoder for feedback. Used for positioning. Old-school CNC axis servos.)
4B. AC servos (brushless permanent magnet, windings energized by magic, used for positioning and/or constant RPM, has an encoder for feedback to the drive enabling commutation and precise positioning.
Yes, there are overlaps in function and terminology but I don't have the reserve brainpower to identify the nuances. How much HP, and at what RPM? What's the max RPM, and is the torque curve fairly flat? Can I position with it, and do I need a magic box just to spin it up? How much does it cost?
With modern VFDs, this line is beginning to blur a bit.
For example, my VFD can position my induction motor due to the encoder, but it'll never be as precise as a true servo simply because the encoder has a much coarser resolution than is typical on 'servo' packages. That, and the rotor weighs a
ton compared to a permanent magnet servo motor of the same nominal power - it just can't start or stop as fast as a lightweight servo rotor.
On the other hand, you don't see 400hp servos (magnets are the limiting factor in high-HP applications), but you do see induction motors in the hundred (or thousands) horsepower range. Pump motors at a municipal water plant come to mind.
-S
