- Jan 3, 2015
- 400
If there's one area of my mill that seems to make sense to upgrade, it's the spindle. At least, if I keep working mostly in aluminum. I use G Wizard Speeds and Feeds calculator, and I find that it virtually always tells me to max out my spindle at its 2200 RPM. On steel (and I don't have a ton of experience here) the RPM is usually much lower and the spindle seems adequate.
I'm really not that determined to increase the horsepower. From what I see in G Wizard, most of the time I'm limited by cutter deflection and not the spindle HP. Plus, I think these are systems, and if the motor is too powerful for the rest of the mill, it's more likely to cause the mill or the drive components (ballscrews, etc.) to deform too much. I'm not going to throw out a good deal on a 1-1/2 HP motor, but I'm not looking for a 2 or 3 HP option, either.
I have the option of a conventional 220 outlet near my mill. If I stick with 120V, the computer, lights, control box, and everything are running on one 15A circuit. I don't think adding more power on 120 is a good idea.
What I'm looking for is something in the 1 to 2 HP range, that will do 5000 RPM (as a guess). 220 AC is preferred. I'd like to control it from inside Mach3, so I think that means an encoder and I suppose that means replacing the control box on the side of the head stock. I expect I'll have to rebuild the headstock, at least partially. Probably improve the bearings. It would be nice if got quieter.
I really don't know what I'm getting into or how involved it's going to be. Can the whole thing be done for $500?
