- Sep 25, 2014
- 1,152
Another approach, if you are serious about improving this chuck (and really determined) - make a new arbor. This is not my idea, but pretty straight forward:
- starting with a suitable candidate piece of bar cut the J3 taper and rough in the MT2 taper (you'll likely use tailstock support so leave it plenty long). Install this on your candidate drill chuck.
- chuck up a little scrap of bar and skim it to make a driving pin (do not remove this from the chuck). For your 5/8" chuck, I'd go with at least a 3/8" pin (sort of mid range for the chuck - of course a larger drive pin would be better, but you want mid range for the chuck). Certainly if you have a dead nuts collet chuck then just grip a dowel and use that for the drive pin.
- go back to your developing arbor - trim off that tail stock support center (hacksaw and grind/file sort of square). Leave it long enough for the drive flats.
- grip the drive pin with the drill chuck - then carefully (sharp HSS tool, lots of back rake, light cuts, not too fast) square up that outer end and pop a new center hole.
- go ahead and finish the MT2 taper (up to you whether you add the drive flats, they are a good idea, especially on a 5/8 chuck, but not absolutely necessary - depends on what machine you will be using it on).
- final step, check yourself into the "nut house".
Congratulations, you now have a reasonably accurate cheapo drill chuck. The run out will be quite a bit better - it will still be a low quality drill chuck.
Avoid all the above - buy a good drill chuck and arbor. As DeadAim pointed out, it does not need to be USA built, just good quality.
Credit to others:
http://www.chaski.org/homemachinist/viewtopic.php?t=87063
Credit to others:
