So I have a question about trying to improve the runout on a cheap drill press chuck. I have searched and read most of the treads regarding chuck removal and repair here but I am wondering if there are thoughts on grinding the jaws to improve TIR. The chuck is at least 25 years old and came on a import no name floor drill press. It is a keyed 5/8 inch and the arbor is mt2 and j3 in the chuck. In the past it was used exclusively for wood and it really didn't matter if the runout was high. Measuring with cheap dial indicator, the arbor and body only have .003 TIR but a end mill shank held in the chuck has 10 to 12 TIR. Spinning the end mill 180 degrees it still reads the same runout at that "spot" on the chuck so I assume it is in the jaws. I have not had the chuck apart but I have soaked it in wd40 and it works smoothly. Any thoughts on how to improve the jaws? Other ideas? I realize I will most likely need to get a new chuck, but kind of fun to fiddle and learn for this Nube. One last thing. I double checked the arbor runout on my lathe and both the arbor and nose/body read .003 TIR. But in the chuck 10 to 12 thou. Thanks for your thoughts.
