Hi All,
I have procured a 1/4" by 3' rod of Invar. Given the price, I had hopes of a clean, tight-tolerance finish. Alas, the surface finish is relatively poor, as is the uniformity of the diameter.
Aside from improving the finish, I had wished to turn parts that would slide nicely on the rod without wobble or binding, but it looks like the rod would need work first. Therefore, I'd like to polish it a little with emery cloth, preferably with mechanical assistance, and maybe even see if I can improve the tolerance on the diameter.
I have a 17" Sherline lathe which can fit the rod down its throat, but of course it can only hold half of the rod at a time (which needs to remain full-length). I don't see using centers or cutting tools on something that thin and long (I do have a steady-rest, but no follower-rest), but emery cloth might work if the rod can be held safely.
In addition, I'll have to cut, face and turn down the diameter on both ends slightly to allow for threading. But again, using the lathe with almost 3 feet of rod spinning out the back of the lathe, even if "slowly," sounds like trouble.
I could likely improve the surface finish manually if necessary, but what other ideas are there for finishing the surface and possibly improving the tolerance of the rod?
Thank you!
Thank you!
