I purchased a similar set from LMS when I started. They worked ok, but you find out pretty quickly that there are only a few sizes that you will use regularly. That may be the best thing about these sets.
I still have the set, most of the mills are chipped and they just sit there in that "fancy" wooden box. I honestly don't think they are that great a deal. The uncoated import mills ("Interstate" brand) from Enco are actually not that bad, and are cheap. Grab a few of those in sizes that you think you will use, and start keeping an eye out for sales (often you can get the name brand stuff for nearly the same price as the import stuff if you get it on sale, or with a discount, or both). And yes, the higher end cutters are noticably better. The import stuff is usable, and fairly sharp, nice when you are starting out, and you know you are going to break some things. Once you stop breaking things, invest in some nicer mills. I have some OSG cutters, and they are RAZOR sharp. I am keeping some in reserve for soft plastics.
For aluminum I really like the 3/8" 3 flute carbide mills from Atrax, or the 1/2" 3 flute rougher finishers from Lakeshore Carbide (though, they are pricey).
IMO the box is not a feature, it just takes up space. Keep your eye out for a used machinist toolbox (they have lots of small drawers that are ideal for storing mills) and keep your cutters in there. I got my Kennedy box for $40 used IIRC, and it works great for organizing mills/taps/etc.
