- Feb 8, 2014
- 11,187
Yes, it will be safe, The mag switch is doing the heavy lifting, the toggle switches are switching the coil in the mag switch. The coil draws maybe 1/10 amp or so, almost nothing relative to the rating of the switch.
If you were using a 240 Volt, 1.5 HP switch, and trying to run a 120V, 1.5 HP motor directly with it, then that would not be safe, because the current draw of the motor would be twice the current at 240V.
