Makes a good case for .... putting things away when you're done using it.
Yeah like that'll ever happen.
I would use divided drawers or boxes large enough to store at least a dozen bits of each size. You'll wind up, after measuring and sorting, with a dozen or two of one size and few of some others. When you want a bit later, you'll be able to see all of your stock in one place, and can choose a new one, or one ground for brass, or maybe an old one that's "good enough" or is expendable. You can buy one index and fill it from the stock drawers.I plan to buy a handful of drill indexes to store them,
i also use calipers, but I lay the bit lengthwise parallel with the jaws. That way you get about 40mm of contact along the flutes. Hopefully enough to ensure the major dia is detected. Another problem with taking readings from the shank is the possibility of jaw marks/burrs/spin scores, giving false readings.I use a set of calipers. I turn the bit backwards till the calipers read straight across the flutes of the bit.
