- Jun 20, 2020
- 31
Try your local high end bicycle shop - if nothing else they may have the right size loose ball bearings in stock
If you have the room in the casting, you could re-bore for a more readily available sealed roller bearing. Mike
Clean it up and take it and the mating part to your local Motion Industries bearing house. They may not have it in stock but can source relatively quickly.I will look for some sort of number on it, I'm guessing there isn't as there is very little surface are to put it on. I think the situation is, there is very little room for bearing/race etc.. its on a 15mm shaft that fits in a 19mm hole. The essentially need these 1mm bearing in there and there is room for very little else. We have a total of 2mm per side of shaft, that's not much room for much more that these bearings and the inside (ID) race. I'll keep you posted...for those who are interested. Any suggestions from anyone that recognizes is still welcome...
I learned this lesson making parts for pasta machines, which have a lot in common with sewing machines. I made the mistake of documenting some new replacement parts before we were informed that they ALWAYS required modification. The only thing worse were Argentinian copies of Italian machines.Who knows what evil lurks in the hearts of Italian design engineers. Mike
