- Sep 20, 2012
- 560
Hi Guys, I'm making a replacement for my carriage traverse gear case assembly, the original gears were held onto squares at each end of the shaft, not such a good idea as wear makes them loose.
I have eliminated the problem one end by making a one piece small gear and 1/2" shaft.
Next step is to make the larger gear and attach it, it has to be removable to fit the shaft in the case.
I'm now a bit stuck as to what fixing method to use, there is very little room between the shaft end and the apron so a nut isn't won't fit, although a countersunk screw may just be possible.
I'm hoping it shouldn't need taking apart again, in my lifetime anyhow :lmao: so I wondering about shrinking it on (oven and fridge method) with maybe a chemical fixing or screw in the end as backup.
Not high speed and not a lot of torque.
So I'd really like ideas, or even better how you have done a similar job that has worked well?
Thanks Bernard
Thanks Bernard
