Idea for holding coin on mini lathe
I don't have a clue. Honestly. What modifications would you want to make to a coin?
I'm trying to help..... if you don't want help...don't post.
Not everyone is thinking the same way you are.
I see, i want to hollow out the coin as above photo . Thanks.
Sent from my Galaxy Nexus using Tapatalk
Hi everyone ,
Is there are better method to hold a coin without using collet? Since my sieg c0 lathe cant not use it.
I have tried to hold by chuck but cutting tool will crash to it.
Thank.
I have made 2 sided half dollars and to hold them i chucked up a piece of aluminum and bored a recess slightly smaller than the od of the coin and tapped (with a hammer) the coin into the recess . It worked very well be sure to put a thru hole in the aluminum so you can tap the coin out when done
take a chunk of bar stock and do the following to it.
1. turn it to a diameter no more than 1/8" (3/32" or 1/16" might be better depending on material) larger than the coin you want to work on.
2. face the end
3. bore a recess in the end just large enough to hold the coin
4. through drill the bar, make the hole slightly smaller than the recess. You need a surface to register the coin on
5. slit the bar length wise with a band saw or hack saw
you now have a custom collet, that you can chuck in a standard 3 or 4 jaw.
