- Apr 30, 2012
- 2,401
these are my reasons and my opinion
I was scared i was going to waste money i really didnt have on a machine that would be below standard and to complicated to learn.
so i started researching and found these problems for home cnc
1. there is no standard for the terms used by the manufactures of parts, the writers of software and just about every aspect of the building of your own cnc. I'm a auto mechanic and could not imagine a spark plug being called something else because another company made it. so for me to read most any literature on cnc i needed a list of terms and definitions to figure out each sentence. and that list is for just that manufacture. thats a lot of lists
2. ok it's killing our economy but without the chinese only the fortune 500 companies can do this and that brings us to translation. this guy in china reads chinese well but does not understand how the sentence translates into a readable english or any language for that matter to form a sentence so lets just pic an english word and put it down. no matter how you read it "cintered canine and crushed paste of yellow zest" is not a "hotdog with mustard"
3. wiring. just about anyone mechanical can modify the machine and do a good job , make it accurate with low cost ballscrews because cnc compensates for backlash automaticly when set up properly. the fact is wiring a cnc is as easy as playing with batterys , lightbulbs and switches like you probably did as a kid. here is the catch anyone can connect wire a to terminal b as per the instructions. nope the breakout board instructions say connect a wire from step+ on the breakout board to step+ on the motor controller. what is the controller i have a driver and it does not have the word step on it anywhere. it says pulse. your thinking magic smoke. the fact is the driver is the controller and step and pulse mean the same thing. so wiring now is a nightmare for the same reason as item 1. terms and standards.
4 learning the cad and cam programs and their cost. you are not nasa you need a cad software that draws circles squares rectangles ect where you want, then the size you want them, and saves in a dxf format. thats free online everywhere i use emachine shop it is so simple you draw the box and up at the top you say the box is here in x and y and it is this high and that wide thats it. drop a circle on the end delete the unneeded lines an you have a bullet. cam software same thing you want simple and low to no cost. are you really needing a software that cuts 5 axis in full blown 3d i cant even think 5 axis yet.
i have a bunch of free programs all limited but when you have them all you can do almost everything.
unless you want to just make scrap you wont write complete programs to finish a complex part in unending steps you very quickly pick the cut from the drawing and tell it the cutter size left right or on center, depth per pass and total depth. run it. thats good pick the next pocket corner and
continue. It is faster than reading prints mounting rotory tables and turning cranks and it dont get tired. It's working, your on the lathe making something else.
just my opinion and i guess you can tell i like cnc or anything i can make behave with my pc
if i could just mount steppers on my wife what a life this would be.
What Do You Think
steve
What Do You Think
steve
