- Aug 26, 2013
- 1,061
Gunrunner you need to order a set of these for the Z axis hand crank. Bill did you just spit coffee on your monitor? :rofl:
I like the flap disks better. They last longer and are cheaper.To clean the tube I used one of these.
http://www.homedepot.com/p/Avanti-P...oven-Quick-Strip-Disc-PNW045STRB01G/202830907
A less aggressive wheel that will still last longer than the non-woven discs is a non-woven flap disk:
http://www.lehighvalleyabrasives.com/abrasives/non-woven-abrasives-surface-conditioning-flap-discs
I noticed your double nut arrangement on top of the drawbar and I was wondering if they ever work loose? I used a grade 5 rod coupling nut that I red loctited on. Probably overkill, but it shouldn't come loose. Hopefully.
I had similar dealings with my 932PDF.
Created a bushing that fits nicely.
Snapped the roll pin that was in the upper nut.
Removed lower nut completely.
Shortened the drawbar so that it fit nicely with all my R8 devices.
Cut a bit of relief on the top of the nut.
Tigged the nut to the drawbar with Weldmold 880 (Super nice filler rod--although difficult to locate and very pricey).
Game Over!!
Jerry in Delaware
