- Sep 29, 2017
- 2,295
I am not sure yet how I am going to bill this apart from material price,so I am not sure if the profit will be enough so that buying a bender will be justified.
Why 40mm?I would cut a piece exactly 40mm long and put a bend in the center and measure each side to determine what is changing. At work we use a top die with a 094" radius. This will generally add one material thickness to each side of the corner.
Joe
Brino in my first post I think I mentioned thickness at 0.9mm stainless steel sheet and the internal length is 110mm with sides of 19mm from internal base to the top of the side.We need a bit more info to make any recommendations.
two more dimensions: sheet thickness, and length of bend.
material type will affect the strength of machine required
-brino
I do have a pneumatic hydraulic 10ton press.We need a bit more info to make any recommendations.
-brino
Pardon me,but is this a computer program?Draw it up in OnShape using the sheet metal feature, it'll tell you exactly where you need to be heading given your desired bend radius and K factor for the material.
You are apologizing too much my friend. No worries here.Sorry Michael it's my fault; I entirely missed the thickness and material you stated.
I need to slow down and read better.
But we're still missing the length (or is it width?) of the bend right?
(ie. do you need a 200mm brake or a 1000mm brake to do this.)
My apologies,
-brino
Thank you very nuch RJ for this, I realy appreciate it. O the width is also 19mm. Once again thank you.As to the original question about dimensions, here is a SolidWorks drawing reflecting the final dimensions and the flat sheet dimensions. I made some assumptions as to bend radius and width. but you get the idea.
Edit: I used .8mm instead of .9mm for the thickness on the drawing. The second drawing reflects a .9mm thickness and I also changed the inside bend radius to .25mm.View attachment 370168View attachment 370171
