I need RPM settings please
muscleflex
Jul 27, 2014
90
Hi, I need rpm settings please for the below material and usage if anyone can help?
FACING:
aluminum rod: 6mm diameter
mild steel rod: 5mm diameter
stainless steel rod: 3mm diameter
PARTING:
I have a 7x14 mini lathe. It has a digital readout.
For facing.. I started using between 400-600rpm for the aluminum rods
I have not parted yet. I just got the parting tool last week: http://www.ebay.co.uk/itm/141031590854?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Any help pls would be greatly appreciated. Thanks
When I part I run it as slow as it goes which is about 100rpm. Thats to fast some times on my 9x20. Go very very slow on the feed.
Thanks - I have looked at this in the past and it just really confused me! :(
so... for example for my 6mm aluminum rod (just a tad smaller than 1/4"), is it 250rpm or is it 400-700? there's two columns which I don't understand on that link. One is Ballpark CS and the other is Cutting Speed.
well you need to find the cutting speed for the material. Then calculate the rpm and such. (CSx4)/Diameter. Then your feed is number of teeth x rpm x feed per tooth
http://www.southbaymachine.com/setups/cuttingspeeds.htm#Feed Rates
Is this right?
Ballpark CS for aluminum is 250. and if my rod is 1/4" then using the formula (CSx4)/diameter will give me
250x4 = 1000
1000 / .25 = 4000??? that can't be right? 4000rpm?
Seems to me on steel be about 1500rpm. Now cut that in half and work up towards it till you find the right finish.
http://www.custompartnet.com/calculator/turning-speed-and-feed
The real trick to these things is knowing the cutting speed for the material. Not the rpm or your feed rate. Use the CS to calculate the rpm
This site has all the info you need to figure out all this stuff. I just open a window for the info's needed and a window for the calculator
I believe I gave you milling calc first..
Cutting speed (100) x 12/.25 = 1528rpm
Wow I never thought it would be so complicated!!! :(
Thank you for the help tho. I have something to go by now.
It's not complicated so much as alot to learn at one time. This is the page I was really looking for here in the link. It has everything you need to know. Use the chart to find the cutting speed(sfm). For your machine I would start at the lower number in each given range.
http://its.fvtc.edu/machshop2/Speeds/RPMcalc.htm
I have to go over all this every time I do it so dont feel bad
