I modified my intake manifold
I have a General Tools EZ Pro doweling kit. Don't remember where I bought it. They are available in most hardware store.
Could you use the gasket the carb uses to get holes where they belong?
That could work if I had one, but I don't. The one between the carb and the other manifold was pretty much dust. Using the calipers to swing a couple of lines is probably more accurate but either way, it worked out great. I'm probably going to have to make a carb gasket for it. There may be a rebuild kit available for it but at a heafty price. I've got gasket material in different thicknesses. I'll see how it runs, if it needs an accelerator pump I'll rebuild the carb.
