- Jul 28, 2017
- 2,593
In this case, it's sucking some old gear oil out of my 4x6 bandsaw's transmission box. It's a "homer" bucket with a lid that has two adapters installed. One is a brass fitting with a tubing ferrule on one end and the other is threaded into a hole in the bucket. A short length of tubing is attached to the inside end so fluid droplets don't get pulled into the shop vac hose (yes it can happen). The other fitting is a plastic bulkhead with a glued-in aluminum insert I turned, to attach the shop vac hose to the bucket.
I originally made this to help change out fluids like old engine oil in things like lawnmowers -- usually a really messy job, but this works like a dream. Sucking out ATF or power steering fluid is easy too -- it seems the drains for those also are in prime make-a-mess places too.
Since the bucket is attached to an operating electrical appliance DO NOT use it to suck gasoline or other flammable liquids!!
I made this thing awhile back so it's not in the "what did you make today" section of the forum.
It can be seen that the bucket has collapsed under the vacuum (but it's still doing its job). If I make another one I'll make a reinforcing ring out of aluminum or steel rectangle, sized to go about halfway down the inside of the bucket.
