I look around auctions a bit and I found a local auction with two Rockwell drill presses, one was a pretty standard column drill press that was also an automatic-reversing tapping machine, the other was a 15-127 Ram type radial drill press.
As the auction went on, the more standard drill press exceeded my best price before i bid so my focus shifted to the 15-127. As the auction was nearing its end, it was just over $100. I was prepared to go over $200 but i like to leave some room for bidding if someone is bidding against me so I bid $161 and as the auction ended the best bid anyone put in was $158 so $161 won and after tax and premiums the total was a few cents over $190.
In the auction pictures the machine looked clean but it had a wooden cover over the table. When i went to pick it up I removed the wood and found the t-slot table perfect except for one small swirl of surface rust and the four holes in the coolant trough that the wood was mounted to.
Now the bad news: it's a three phase machine so I'm pretty sure I need a VFD unless a perfect single phase motor falls in my lap. The ram way stop doesn't seem to have the right lever hardware. One of the ram way wipers is missing. And finally the handle that holds the rear belt guard up off of the motor bracket is missing so the cover runs on the motor pulley. Only the ram way wiper is a critical thing but I hear Rockwell spares might be available so my restoration might be 100% correct.
Bottom line, I doubt I'll be more than $600 in to this for a perfectly restored "survivor" drill press, upgraded with a VFD...
The VFD is going to be around half of that but I'll try to make it do tricks.
This is one of the best condition auction tools I have ever seen and I got it cheaper than a rusty old column drill press (with tapping feature).
So, that's my brag, now I just have to get it running on a VFD...
