Hey All!
Been prepping to make a stud for my toolpost on my lathe, and I decided to practice single pointing a little bit today:
It came out well, I was trying to test how much stick-out I could manage and get it to cut down. The bottom thread I'm holding was actually my first try, and after doubting myself, I slipped a die on part of it, only for it to slip in the chuck and force me to start over. On the second try I did the threads on top.
That's pretty OK looking for just getting going.....
Overall, I cut 1/2-13, because I had hardware I could test fit with, and my 'production' run will be m16-2 threads, which is comparable speed to the 13tpi.
Be careful using hardware grade nuts and bolts as "gauges". They're sloppy. But if that's what you're building stuff out of..... I'm not saying it's wrong..., just be aware, and careful.
So, on to my question. I saw diameter #'s out of the book as .500 and ~.405, or 95 thousandths to cut on the diameter. Half that being 48 thousandths to cut, and with my compound at 30*, doing a bit of math, I figured 55 thousandths on the compound would get me to where I needed to be. <-- Does this track? Did I do this right?
Books and tables are a good thing, but they require some attention to detail. They tend to be based on a theoretical sharp thread profile, which in the real world is not a workable thread. The crests and the roots are actually flattened and rounded from the theoretical dimensions. This will affect your depth of cut tremendously. If you know the root radius accurately on your threading tool, and your starting diameter, you can do the math on that to figure how much "theoretical depth of cut" you're missing when the rounded tip makes contact. Then "trig" the compound to get your infeed amount.....
I cut down my stock to .499 diameter, and then cut the threads with the numbers above, but it was way too tight for the handful of nuts I tried (only thing I have to test with). After several spring passes without it fitting, I ended up cutting another 10 thousandths (65 total) on the compound (55 thousandths total depth on x-axis). It now threads smoothly with every 1/2-13 thing I could find in the garage, so it works.... but I feel like I got to the right answer the wrong way here. I don't have a way to measure minor diameter, any problems with that extra 15 thousandths cut?
Appreciate any advice as always, and if you see anything wrong with the threads in the picture I'd love your feedback! Go hard on me here, trying to get better.
So, I'm speculating here, but I suspect.... You've got threads that are more pointy on top than they should be, and thinner than they should be, relative to the valleys, and your nuts are "riding" on those peaks, without fully contacting the flanks of the threads
Advice number one- After taking what I just said with a grain of salt, as I'm not looking at the part the same way you are, and I'm not feeling the nut on it the way you are.... Advice number one is to validate or invalidate my suspicions about what's going on with your lack of fitting right when the dimensions should have been right. I could be off on that speculation, but I'll guarantee it's an easy way to screw up a thread. Trust me, I checked. More than once.
Advice number two- It's cool to be able to make threads "by the numbers", and just make stuff that works. I'm not there yet...... My method (and I don't stop keeping track of or paying attention to the numbers) is to do it like this: I'll take the threaded thing down to it's final actual diameter (NOT nominal diameter. For a "standard" screw thread, there is a range you can be in, but an easy spot to be, without compromising much of anything, a comfortable place to be is nominal diameter less 10 percent of the thread pitch. So in your case, a half-thirteen thread, I'd take the thread pitch (one over thirteen, or 0.0769 inches, call it 77 thousandths), ten percent of that, call it a shy eight thousandths, so 0.500 (nominal) less 0.008 tells me that the unthreaded blank would be 0.492 in diameter to start.
By doing it this way, I will not have any interference with the rounded roots of any internal thread I've cut (or any nut that I've bought, I'm guilty of that too...), so that as I work out theoretical numbers, as I watch closely to see when my thread starts "looking like it should", in case I'm off base and it starts looking OK before the numbers say so, and I can confidently "guage" the thread with a corresponding thread, knowing it's NOT binding on said pointy peaks.
For me, (admittedely an amateur) this keeps me very much out of trouble, and keeps me making functional threads, even if I screw the numbers up.
And to be clear- There's a thousand ways to approach this. Nearly that many are socially and morally acceptable. I know many prefer to thread first, and then flatten the crowns, and there's nothing wrong with that. But doing it this way is just an approach that works for me. Maybe it'll work for you.
Or..... If you're really in a pinch, if you're having trouble getting a good finish on the threads (the larger they are, the worse that is), if you're locked into a boarderline workable but not ideal overhang level, and taper is an issue... Single point as much of the thread as you can, without blowing the final size anywhere. Then, with 80 percent or more of the material removed, you can run a die down it, which will follow the thread keeping the effort at just a small fraction of what it would normally take, the die will follow the cut threads, both forcing it to start and stay dead straight, not just straight enough, and keeping as much pitch accuracy as your lathe has over as long a distance as you can do by single point cutting, which is a WAY better result than just straight up using a die. It is a kick in the pride to do so, but it's an awesome crutch, maybe even a bailout, when you're half way done threading the last piece of rod you own in that size, and realize that things aren't going as ideally as you'd like.
