- Oct 21, 2021
- 63
Hey All!
Been prepping to make a stud for my toolpost on my lathe, and I decided to practice single pointing a little bit today:
It came out well, I was trying to test how much stick-out I could manage and get it to cut down. The bottom thread I'm holding was actually my first try, and after doubting myself, I slipped a die on part of it, only for it to slip in the chuck and force me to start over. On the second try I did the threads on top.
Overall, I cut 1/2-13, because I had hardware I could test fit with, and my 'production' run will be m16-2 threads, which is comparable speed to the 13tpi.
So, on to my question. I saw diameter #'s out of the book as .500 and ~.405, or 95 thousandths to cut on the diameter. Half that being 48 thousandths to cut, and with my compound at 30*, doing a bit of math, I figured 55 thousandths on the compound would get me to where I needed to be. <-- Does this track? Did I do this right?
I cut down my stock to .499 diameter, and then cut the threads with the numbers above, but it was way too tight for the handful of nuts I tried (only thing I have to test with). After several spring passes without it fitting, I ended up cutting another 10 thousandths (65 total) on the compound (55 thousandths total depth on x-axis). It now threads smoothly with every 1/2-13 thing I could find in the garage, so it works.... but I feel like I got to the right answer the wrong way here. I don't have a way to measure minor diameter, any problems with that extra 15 thousandths cut?
Appreciate any advice as always, and if you see anything wrong with the threads in the picture I'd love your feedback! Go hard on me here, trying to get better.
