- Jun 12, 2011
- 581
I've been in a few of those plants and refineries around there Tony, but it has been probably 10 years or so. We set welding procedures on every job and everything is 100% x-ray and for the most part we do a pretty good job of monitoring it all but that is not to say there will never be a problem. Occasionally we encounter a spec where the root bead is mandated to be TIG welded and this is mainly done to minimize the dross introduced into the piping on existing systems as opposed to most chemical plants/refineries using TIG due to high chrome alloy material. 99.9% of the stuff I deal with is high carbon steel with some occasional stainless steel. Many years ago I built a plant near the Canadian border during winter. Water was really not an option to hydrotest with so I used diesel instead. This turned out to be a very cost effective solution as we re-used the diesel over and over and did not have to worry with drying the system to a specified dew point afterwards. In the end we ran the diesel thru some really fine sock filters and used it in various equipment and even vehicles on the job and also used it to heat with in big smudge pot heaters. I bet there was less than a gallon spilled accumulatively and by far this was more environmentally friendly than having 20,000 gallons of glycol and water to dispose of.
