Hydraulic cylinder for 4x6 band saw downfeed
MontanaLon
Mar 15, 2019
713
I have wanted a hydraulic dampener for the 4x6 band saw since I got it. I've seen the various builds here and also seen the complete unit for sale online for $180. I have sourced the parts and it appears I could almost double the cost of the saw I am not opposed to it but if I could do it cheaper that would be a plus in my book. Not to mention I could use the practice in fabricating and machine work.
So I did what any home shop machinist would do, I went to the scrap pile, I mean stock of pristine raw materials waiting to be freed from prior forms which seemed useless.
What I found was a length of 1.25" OD x 1" ID aluminum of undetermined alloy. In its' prior life it was a display built for wind chimes and is painted black and had some holes at each end and in the middle but with several feet of useful stock in between. Bingo, there is the cylinder for the hydraulic cylinder. I lop 10 inches of it off using the saw which will be the recipient of this project.
Then I have some 1.25" steel shaft which will become the end caps and piston. At this point 85% of the mass of the thing is decided upon but now my scrap pile is exhausted of future HC components and I have to go shopping. I do some rough measuring and sketch out a "plan" on a junk mail envelope.
I set off with the 3 hellians in tow to the local hardware store. I seek parts while they seek toys and torment the employees. I quickly find a 3/8"x10 zinc plated grade 2 bolt which appears by all measures to be hiding a HC rod in nearly plain sight. Shortly thereafter I find some o-rings which judging by my crude measurements will effectively seal the end caps, the piston and the rod. More likely of course is they will direct slow leaks of hydraulic fluid into streams which will rival a waterjet in their ability to soak everything in sight.
I gather up the kids and leave the frazzled employees to restock the toy aisle which by all appearance was struck by a mid-December tornado outbreak. Sum total bill, $3.08. Hearing the weeping from the toy aisle, priceless.
At home I had a little time before shower and bed time for the wrecking crew to get a little chip making in. So I popped a DVD in the player and hit the play button on the kids' favorite movie. The 1987 classic by Stanley Kubrick, "Full Metal Jacket". I retired to the basement where I could hear Gunnery Sergeant Hartman berating the recruits in an artistic display of profanity and the giggles of the 12, 7 and 4 year olds glued to the screen and hanging on every syllable of the profane poetry. Really, they were watching Paw Patrol, FMJ is what the wife accuses me of letting them watch when she goes out to drink wine with the "ladies" from the hospital. I head to the basement while they are occupied with the TV and G-rated programming.
First I true up the ends of the cylinder on the lathe. The interior walls seem to be fairly smooth and consistently measures 1.05" with the caliper. Since I have no way of honing the interior of the tube, smooth and consistent is a good thing. Then I move on to start the piston. I face off the stock and turn the OD down to 1.045. A little polishing with emery and it looks pretty good and slides freely into the tube with no contact and very slightly perceptible play. I then use a parting tool to cut a groove for an o-ring. The o-rings are 1" OD and .1" thick so I need to give them just the right depth to sit in the groove and fill the tube but not bind. My calculations are the groove needs to be .093 deep to create a seal which can move freely with the o-ring. I cut the groove to .090 and test it. I find it binds so go in and take .003 more and test again only to find it fits just like the piston without the o-ring did, freely with barely perceptible play.
Every piston needs 2 rings at least by my judgement so I cut another groove .090 deep and test it again, this time using a little oil on the o-ring and find it slides smooth. I drill the piston for the rod and then go to part it off and promptly break the parting tool. "Shat" and from behind me I hear a little 4 year old voice, "shat". I turn and there is my 4 year old grinning wearing his goggles, "whatcha doing Daddy?" "Don't tell your mom I said that." "Said what?" He is a good kid or has a very short memory but at least he wears his PPE. I let him watch as I change from a carbide parting tool to a HSS. I creep it deeper and deeper and am within .05 of parting off when "craaaaaacrunchhhh" it grabs and snaps off. The 4 year old says "shat" and laughs. It is bath time, if I can't wash his mouth out with soap I can at least try to keep the external bits of him clean.
Once the little ones were clean on the outside and asleep I finished the parting off and did a test fit. With just my hand over the end of the tube I can build pressure, time will tell if I end up with something that will hold hydraulic fluid but even if I don't at least I am learning and so is the 4 year old.
To be continued.
Episode 2, half way there. I've not had much tool time, damn bosses. But I have managed to get halfway there. Currently I have created an air spring. I figure if it can hold air it can surely hold hydraulic oil. I haven't drilled any ports on either end of the cylinder for oil or air to flow. It is easier to chase down leaks with fewer areas a leak can be. And it does hold air and vacuum on both sides of the piston. Now I just have to work some plumbing magic to allow me to incrementally adjust the force of the thing and I will have it ready to be attached.
The seals on the rod were the hardest to do. The piston is drilled through which in hindsight was not ideal and I may make another piston before I install it. That will eliminate 1/2 of the o-rings on the rod and will prevent any leaking from side to side besides going through the needle valve.
I've often wondered why everyone uses oil for dampening ? A simple air cylinder with a flow control on one exhaust port works great . :) Atmospheric air is free and it'll never make a mess .
Now that sounds interesting. Much simpler for sure. Could even build a ball bearing check valve into the cap easily. I may have to modify my blueprint.
All you need is a flow control valve . No mess , no fuss . Keep it simple ! :grin: You're only using 1 side of the cylinder , and you meter air out . Pretty simple .
My question is still why hydraulic over pneumatic ? Both are controlled feeds , air is cheap . If your piston seals ever do leak , they sure won't leak oil . Why spend the extra money for something not needed ?
The difficulty is that, when you first start to downfeed, you're compressing the air. This allows uncontrolled downward movement. Once it's at a steady pressure, downward motion is easy to regulate with a flow control. As an example, consider the way an air cylinder is flow controlled. The needle valve is installed on the exhaust side of the cylinder (with a check valve in parallel to allow full flow inward), where the air is at full pressure. If you were to try throttling the air going into the cylinder, you might get no motion at all until the pressure has built up enough to overcome the mechanical resistance. Then the cylinder might well push too quickly.
It's a lot more consistent to control the flow of a non-compressible fluid, such as oil.
