Radials, like your color choice it’s the same as mine. I don’t want to jac the op’s thread just to say if you post a thread I’ll put it on the watch list. I’ll be taking my spindle apart for bearing replacement soon and variable speed drive. Here is a part breakdown if you don’t have one.
Please feel free to post about your mill on this thread if you would like to! I had a hard time finding any information on the 8 x 30's when I was looking to buy. Any pictures or information on 8 x 30 or even 6 x 24's would be great to have.
Thanks Mike, but I think I'll still put together a rebuild thread (at some point) that will be a bit more generic to the 8x30 line of mills. Like Z2V said I don't want to take your thread off topic either.
Nick, thank you for the picture! My mill is shoved in the corner while I am rearranging my shop. I will do my best to get to the nut and get you an answer. Is it holding up your reassemble currently?
Yes, the cap screw is toward the operator, crank handle.
Never really thought about leveling the mill.
The gantry is mostly bolted together. The uprights are three 2 x 4's glued and screwed (Laminated). The top is three 2 x 10's bolted together. The rest is bolted together so I can quickly and easily disassemble it into 5 pieces and stow it away when not in use. I ran out of bolts for the upper braces so they are just screwed on for now. The 2 x 10's sit directly on top of the laminated 2 x 4 uprights. Without any weight the upright 2 x 4's sit about 1/4" above the ground. When I put weight on the gantry the uprights touch the ground and lock in the Y braces nice and tight. None of the lifting weight is on the joints, the lifting weight just gets directly transferred to the floor via the laminated uprights.
The uprights are 8' long... I should have gone 10' long. Oh well, easily replaced with 10' 2 x 4's later. In the lower picture you can see I came up 6" short.
You can kind of see the bases in this picture. Pull out the uprights and the Y braces fold down between the 2 x 4 bases. The Y braces are offset so they fold flat between the bases for storage.
The three 2 x 10's on top can be lifted into place one at a time which makes assembly a lot easier than trying to lift a trippled 2 x 10 eight feet into the air by myself. No casters... the plan is to stow it when I don't need it. I might add casters if the need ever arises but casters rated for a decent amount of weight are pretty pricey.
And thank you!... I am kind of proud of my gantry. With the 1500 lb lathe it didn't even creak.
Ulma, thank you. Very helpful! I was just looking at a set of the Shars collets on ebay last night and realized I had no idea what to look for as far as quality tooling that I would not regret purchasing later. The recommendations are very helpful! Thanks for the tip on using a collet to hold a drill chuck for quick tool changing... something I hadn't thought of but it makes a lot of sense.
A couple pics from the CL add.
View attachment 252793View attachment 252794View attachment 252795
