- Feb 1, 2015
- 9,992
One thing to consider is that old time lathe tools were ground for use with lantern style tool holders. The tool holders generally had a built-in rake angle so the top surface could be used as-is. Modern QCTP and 4-way tool holders present the tool to the work horizontally so the back rake must be ground into the tool. Also affected is the end relief. Tools used in the lantern style holder needed more relief ground into the tool because of the lantern style holder.
When grinding tools, it is important to look at how the tool is presented to the work. The rotating work sees the tool in a plane containing the axis of rotation and the cutting edge of the tool. Normally, that plane is horizontal (parallel to the cross feed ways as this ensures that the cutting edge will pass through the center of the work and that movement of the cross feed is exactly 1/2 the reduction in diameter. However, changing the cutter height slightly can have benefits. Raising cutter height above the centerline has the effect of increasing back rake and decreasing the end relief.
Each lathe has its own characteristics. The available power, and rigidity of the lathe play an important part in lathe tool design. Large lathes usually have power to burn and are massive. What works for them will not necessarily work for a small bench top lathe. This should be taken into consideration when grinding your tools. It would be very frustrating to grind a tool exactly like one known to work well for another lathe and find that it gives totally unsatisfactory results on your lathe. Use some of the principles as a starting point and do some experimenting for your particular best geometry.
