How does your wooden propeller machine function?
Pretty good, thank you. Its a can of worms, invented by a real mechanical genius.
The short version is "there is a vertical cutter (7/8" 80 grit sanding roll 3" long which oscillates up and down) spinning at 10,300 rpm, and a carriage which traverses left to right and back, rotating as it goes."
Long version. In addition to the above, there is a template which a roller follows, rotating the carriage, which determines the pitch of the prop, and a profile which another roller follows which determines the profile of the prop. The sanding roll is guided by the profile pattern, the carriage by the template for the pitch. The pitch template is changed for different length props.
The larger props, up to 17" take four or five passes, on each side to get to finish thickness (3/16 at the blade tip) the short ones 6 and 7 inches can be done in two passes each side.
On the carriage there is a 3/32 pin in the middle and clamps on each end to hold the blank in place. Ideally the wood has a density of 4.5 to 8 pounds per cu ft. Softer it won't hold up the sanding roll, when it gets beyond about 11 lbs, it tears up the sanding roll.
When we acquired the machine in 2014 it was about 30 years old, the carriage rode on iron ways. It had worn the supports so that it dropped about .015 on each end. I installed rails and ball guides and eliminated the droop. Its driven by a cable drum.
