- Mar 25, 2013
- 5,132
Another idea is to find a bolt that will fit through the hole and then clamp the washer between two nuts. Chuck up on the bolt and go to work. You could even us a 3 jaw chuck and then tap the washer to line it up before clamping it tight for final turning.
Edit: Or if the bolt is threaded all the way, just use one nut and the head of the bolt to hold it. Whichever works out better for you...
Ted
Ted- this is a great idea. I will try it! That's why I post here!
Randy- I have some cerrobend on hand! How would I best use it in this application?
Robert
