I am not aware of that. Just measured a quality 7.5 mm drill bit, the diameter at the tip is exactly 7.5 and reduces to 7.44 near the upper end of the flute. Very interesting. Thanks for the knowledge !
In fact that's what I have been doing but it seems that it's not a very popular practice. I dont have a grinder so regrinding is not an option for me. To use the off-center drill, I drill a slight smaller hole first and finish off with the off-center one. When used in that way, the hole will not be centering around the tip and the diameter is determined by that of the body of the drill hence accurate. The only risk is having the drill grab and wander causing the hole position to be off.
