This gear is on a take-up roll in an offset printing press and has broken. The gear looks more like a hole saw than a gear, but the manufacturer calls it a gear. If you were to make this, how would you go about it. The diameter is about 1 inch and slips into the end of the take-up roll. When the roll is full, it is removed from the press, and the gear is put on an empty take-up roll and starts over again, so it has to be removable.
Patrick
Patrick
