- Jan 24, 2015
- 239
Dear All,
This is a continuation of this thread.
The project is to build steam engine #5 from PM Research:
The part I am currently working on is the main frame. The drawing is below.
All the circled dimensions are high tolerance.
Here is a shot of the part during machining the top bore and it's relief:
My question, now more broadly defined, is how would you go about centering this:
under the spindle to machine the inner surfaces of the journal bosses.
The inner distance between boss surfaces has a tolerance of ±.005, and they need to be square to the crank axis. See this drawing below:
I have already machined the central bore and relief on the top of the frame (bottom in the set up picture above) and the crankshaft journals. My goal is to use that bore plus the crankshaft as a reference to machine the inner surfaces of the crank journals.
So, hints, tips and tricks will be much appreciated.
And, the winner gets a prize. Not from me, mind you, but if you live long enough you eventually get a prize.
I am missing something, that I know. Unfortunately, it is a known unknown of an enigma.
Thank you all for your help and suggestions.
Cheers,
Tom
Cheers,
Tom
