- Feb 8, 2014
- 11,176
I don't have the knowledge to actually grind my own tooling. This would be a handy skill to have. Clearly I can see the benefits and needs
The way you gain the knowledge and skill is to just do it. The cutting edged sticks out further than everything else, all of the other surfaces are just clearance. If you can sharpen a cold chisel, you can grind lathe bits.
A cheap bench grinder or belt/disk sander and a random piece of metal makes a pretty good practice platform. Useful tool bits can be ground from many different broken tools. Broken taps, broken drill bits, broken end mills. I save all of the broken bits and I tend to generate quite a few .
BTW, I use my bench grinder with a standard aluminum oxide gray wheel for 99% of my carbide grinding, you just have to push a little harder. Grinds pretty fast once it gets red hot.
