Nearly pure copper can grab, although it isn't that likely to happen when facing. I've turned a few copper bars that were C101 and its great unless it grabs and then it digs in. I used a HSS knife tool to face and it cut beautifully with stick wax of all things. I turned it with a brass turning tool - 15 degree relief angles and a flat top, honed well and a 1/32" nose radius.
Speeds are tricky. Its tempting to go fast but copper tends to catch and crack if something goes wrong. For such a large work piece, I would try facing it slow and see how it goes. Looking back at my notes, I turned my rod at 60 sfm and it worked okay with a slow feed. I suspect you can go much faster with a facing cut, though.
May I suggest you consider making a flange with an integral rod to fasten to the back of the piece. The shaft of the rod will go in the chuck and you can screw the work piece to the flange. If it catches, it won't go flying across the shop that way.
How are you going to finish it? If you want to preserve the copper finish, Everbrite might work but I'm not sure; I only used it on brass and it works well.
