The 0 marked key hole on the three jaw chuck is the one marked by the manufacturers as the hole to use for best repeatable concentricity, which begs the question "so why would you want to use the other two holes ever?" and I suppose the answer is "when it really doesn't matter" (whenever that is).
Xalky, I like that idea! I will try it next time I am dialing in for accuracy!
To all, If you look at the specs of a new, good quality 3 jaw chuck, you will see that the concentricity is rarely specified as greater than .003", which is, I assume, the repeatable concentricity. You can get nearer than this with a bit of tapping and dialling in, but if you want better, "the most accurate chuck you posses is an independant 4 jaw"!
Phil
Nearly there
:think1:I suspect that the three holes are there to be used :rofl: ( more of this later ) .
Those chucks with the " master " mark tend to have that mark where the start of the plate screw thread starts so is it an easy or dumbed down way of putting the chuck jaws back in the right order at the starting point if you have had them out ?
jaws MY 3 jaw lathe chuck simply has 1or 2 stamped on two of the jaws & 1&2 on the body , both sets of the four jaw chuck jaws have either 1,2 or 3 on their jaws . There are no official line up marks on the body or the back plate .
Though after gently scribing matching marks on the body & back plate of my three jaw lathe chuck , the stripping & cleaning when I first received it ( it was difficult to open & close ) I found it still stiffer than I wanted so I rotated the back plate one hole and found it a perfect fit/movement .
I then dot punched align ment marks on the new favoured position of the body & back plate .
I guess it's assumed that the operator has the intelligence to work out where the unmarked jaw goes :roflmao:.
RE:-
The three holes , if you continually only use one hole to tighten the chuck it will eventually wear in one segment of those gear teeth involving the jaw spiral closing drive lips and become out of kilter so to speak. It will not run freely in the end , frequently binding up on both opening & closing of the jaws . ( A bit like starter ring wear on car engine flywheels & starter motor bendix drives jamming/ wearing ) .
There is also the possibility that by only using one hole you can end up with the work piece being gripped out of line. If you use all the holes and give them a nip up via them you'll normally discover any irregularities and rectify them before doing start up on the machine .
It's also simply good engineering practice to spread the stress load evenly when tightening things up , so it is distributed evenly over several places unless specifically stated by the manufacturer or after hundreds of years of hard won experience by many people .
I think I can truthfully say that in my 50 plus years of tightening various chuck of my own that have zero or minimal wear on the jaw faces & using all available tightening points in gentle rotation I have never ever had any drill or work piece slip .
I have however had things slip if I have not done it evenly and one of my ancient 1/4 & one of my 23 / 64 ths much sharpened twist drills have the battle scars to show it.
