I gave this a smidge of thought and here would be my suggestions from a guy that spent one summer forming concrete. ideal would be tieing into the existing foundation with some no4 rebar. I would also make the new pad about a foot bigger on each side of the mill, maybe more in the front if you are tallish.
i would make the pad an easy 6" and use mesh. I would make the sides 8" (making a mini footer). and i would drill holes into the sides of the existing slab with a 1/2" bit. slide the bent no4 into those holes then tie the no4 to the mesh. throw in a few bars accross for ****s and giggles, and spend the next day carrying buckets of concrete in.
the idea is overkill is way easier than doing it twice, or worse having your mill list after 3 winters.
dont forget some visqueen, pick up some heavy duty in the painting section of home despot or Lower than Lowes.
