Get a drift punch same size as drill bit.
If you are touching bit from other side then try this.
Grind new tip to broken bit but as flat as possible to get as much material removed from where tip of broken bit is.
Or use dremmel tool.
Get a GOOD drift punch and biggest hammer you have and use drift punch against broken bit from small end.
If real lucky it pops drill bit through.
If more lucky it pops pin out.
Sent from my SM-G781V using Tapatalk
