I was doing a transmission oil change, and I broke 3 bolts so far. I was very careful, but I didn't believe penetrating oil would work, or if I would have time to wait for them to penetrate.
So after 3 broken bolts, I am ready to accept being wrong, and hopefully there is some penetrating oil that would work helping me remove the rest of the bolts, and figure out how to drill the other bolts out.
Is there a penetrating oil that would work with steel bolt on aluminum?
I may try again, with a hammer hitting the bolt head a few time before removing them, but I think I need some help.
Also, any tip on how to drill these out? I think alignment is the hardest. Since it's 10mm socket sized bolt, it's very small, and I don't know if tiny bolt extractor will be able to remove them. The other option would be larger bolt, or using inserts.
