^^^ That’s exactly how I have to part off with my little 7x12.If it cannot be mounted in the rear then it will do better with the tool mounted in front with the blade upside down and the lathe run in reverse.
That's how I mount the parting tool also (on a small mini lathe) and I first learned about it from Mikey, parting with an inverted blade and the lathe run in reverse is just one way of doing the job but to me as a newbie hobbyist it is an easy (and safe) method .Then I read about the upside down/reverse method. I’ll admit that at first I didn’t understand why this would work any better, but thought I would try it anyways as it surely couldn’t be any worse than my current method. Wow!…the difference was night & day. No more chatter, no more digging in, no more stalling the wee ½ hp motor out & no broken blades since. Now parting off is just another step to do & I don’t give it a second thought. Pucker factor literally dropped to 0/10.
