Thanks Mayhem. I'm glad they could be of some use to you.
David:
The cutter was a 2-flute center cutting end mill. I chose a 2-flute because they have more clearance than 4-flutes and tend to load up less in aluminum. On the first pass of milling a pocket like this, climb milling is the way to go because the rotation of the cutter will force the table against the rotation of the feed screws. Consequently, the table doesn't need to be locked. On a less rigid machine, you may want to consider locking the stationary axis and maybe snugging up the lock on the moving axis because the cutter will be trying to pull the table into it, especially on the finish pass.
Climb milling can be your friend or it can be your enemy. You just need to keep your guard up be able to recognize the conditions that can get you into trouble. For instance: If you milled the side of a part in the vise and tried to climb mill, the cutter would attempt to "climb" up on the part and pull it in. This would be a good time to use conventional milling AND lock the table AND take the backlash out of your lead screw, at least for the roughing cuts. Climb milling will almost always give you a better finish than conventional milling, the few exceptions being some types of plastics and soft stringy metals.
Thanks for the excellent questions.
Tom
