Both scales look good to me. I believe the problem is reading them. On your 7789 picture, you look for the zero on the top scale. That is the Venier scale, look down and that goes just beyond to 26 degrees. Go to the left until the lines both top and bottom line up. That is the bottom 20 degrees line those lines up with the 21-minute line. Why 21 minutes? Because each space on the Venier scales is 3 minutes apart. Where as the bottom scale each space is a degree apart. You can also double check by going to 27 degrees. Then go to the right and line up the scales. It appears to be at the bottom 30 or 29 degree scale. Can't quite tell, must be the angle, so I'm going to go for the 29 degree and subtract the 3 tics to zero. That is 9 minutes from 30 degrees which comes out to 21 minutes. This is tricky to read since you are dealing with both degrees and increments of 3 minutes. When you set your angles, you need to look straight on. That is why I can't read the scale on your first picture, it's at an angle. Practice will help a lot. I hope this explanation makes sense.
