David, I started not to draw this since you have made the washer but you stated that you might make more. I have done some things like this in the past and I found that something in the sketch works real good. You will want the bottom mandrel since it is repeatable in a collet or 4 jaw.
Turn the washer and part off a tad thicker than finished size. Get the hole, face that touches the blade and recess all concentric. Leave the outside a little over size.
To make the reuse mandrel, turn down to a diameter that you like and face off. Must be concentric to shaft. I use a 3/4" stub shaft for 5C collets when possible. Flip the mandrel around and install in collet or 3 jaw chuck with face flat against jaws. Now turn outside to fit the recess. Turn down small shaft to fit hole in washer and a little longer and face flat. The face, shaft and OD all must be concentric to each other. The OD and face of this side of the mandrel becomes your reference point. If you use a collet, it should be OK. If you use a 4 jaw then you dial it in.
Press fit, glue, Locktite, tape the washer to the face of the mandrel. I try to make a tight fit and heat in a toaster oven a couple hundred degrees and press on with tail stock. You then take a light facing cut down by the shaft so the nut will sit flat against it.
Make a small hollow collar/tube to fit over the shaft and apply pressure to the washer with the tailstock. You are now pressure turning the OD and taper face to what ever you want with out fear of it flying off. lets say you want to make 6 of these. You first do all 6 washer part above and part off. Then dial in the mandrel and and stick them on one at a time.
Here is a drawing. Have a good laugh, but it was quick and dirty.
