How to machine Cobolt
terryw123
Feb 2, 2017
45
I bought a piece of cobolt blank thinking I could cut and shape it to make a lathe cutting bit. But that stuff is much harder than I thought. Carbide won't touch it. Any ideas how to cut it?
Unfortunately the easiest way is to grind it.
The unseen hazards of grinding on cobalt are not worth the risk. Not only is the inhalation of the dust dangerous, it
is also likely carcinogenic. Exposure can cause an allergic reaction and damage one's internal organs. OSHA has
set exposure limits for cobalt exposure for good reason.
I just assumed the OP was talking about HSS-Cobalt tool blanks like M35 or M42 tool steel. But with the misspelling in the title it could be either I guess
Yep, that is M42.
Is M42 good for anything? What are the advantages and disadvantages? What an it be used for?
Terry, what do you mean when you write 'carbide won't touch it'?
