Name: R. Dean Odell
Playlist: GD&T Explained ASME Y14.5
YouTube channel: R. Dean Odell
Channel type: structured, education
List type: playlist all videos, uncurated
# of videos: 88
YouTube:
001-GD&T Limits of Size vs Flatness, ASME Y14.5 #GDT #ASME.mp4
002-ASME Y14.5 Rule 1 Example and Explanation, GD&T "Perfect Form at MMC".mp4
003-GD&T Symbology, ASME Y14.5.mp4
004-GD&T ASME Y14.5 Detail Drawings DO NOT Apply at the Assembly Level, Fundamental Rule P.mp4
005-GD&T ASME Y14.5 Fundamental Rule "A".mp4
006-GD&T ASME Y14.5 "Rule #2" Explained.mp4
007-GD&T ASME Y14.5 Datum Symbols, Surface Application Examples.mp4
008-GD&T ASME Y14.5 Composite Position Tolerance Practical Explanation.mp4
009-GD&T ASME Y14.5 Profile Tolerance Zones Equally vs Unilaterally vs Unequally Disposed.mp4
010-GD&T Podcast Effect Of Datums on Manufacturing & Inspection.mp4
011-GD&T ASME Y14.5 Coplanarity Tolerances. Size, Form, Orientation and Profile.mp4
012-Reading GD&T Drawings Step by Step.mp4
013-GD&T Inspection Flatness, Parallelism and Profile.mp4
014-GD&T ASME Y14.5 Limitations of Rule #1.mp4
015-GD&T ASME Y14.5 "Bonus" Tolerance Explanation in 5 Minutes.mp4
016-GD&T ASME Y14.5 Bonus Tolerance vs Datum Shift.mp4
017-GD&T ASME Y14.5 MMC LMC RFS Explained.mp4
018-GD&T Profile Possibilities.mp4
019-GD&T Axis vs Derived Median Line According to ASME Y14.5.mp4
020-GD&T Inspecting Position Tolerance with Bonus Tolerance Calculation.mp4
021-GD&T Position Calculator In Excel.mp4
022-Sine Bar Calculating Gage Block Height With Excel.mp4
023-GD&T Inspection Which Features to Inspect First.mp4
024-GD&T Profile vs Flatness.mp4
025-GD&T Position, Zero at LMC.mp4
026-GD&T Coaxiality Position vs Profile vs Runout vs Concentricity.mp4
027-GD&T Composite Profile Example, Three Segment Feature Control Frame Explained.mp4
028-GD&T Books for Students, Engineers, Drafters and Inspectors..mp4
029-GD&T Decoding Datums.mp4
030-Tolerance Stackup Simple Assembly.mp4
031-What is GD&T (Geometric Dimensioning and Tolerancing).mp4
032-GD&T Position, Composite vs Two Single Segment.mp4
033-Calculating Position Tolerance Values With Fixed Fastener Formula.mp4
034-GD&T Interview Questions.mp4
035-GD&T Advanced Position & Profile.mp4
036-Engineering Drawing Tolerances (2022 Update).mp4
037-Tolerance Stackup Choosing Dimensions to Loosen Tolerances.mp4
038-GD&T Lesson 1 Four Key Concepts.mp4
039-GD&T Lesson 2 Form Tolerances.mp4
040-GD&T Concentricity Explained.mp4
041-GD&T Lesson 3 Orientation Tolerances.mp4
042-GD&T Position Tolerance Without Basic Dimensions.mp4
043-GD&T Lesson 4 Datums & Datum Reference Frame.mp4
044-GD&T Datums vs Ordinate Dimensioning.mp4
045-ASME Y14.5 Rule J & K, 90 Degree Angles Assumed.mp4
046-GD&T Lesson 5 Runout Tolerances.mp4
047-GD&T Q&A Composite vs Two Single Segment Position, Single Datum Reference..mp4
048-GD&T Custom Datum Reference Frame (6 Degrees of Freedom Explanation).mp4
049-GD&T Choosing Datums.mp4
050-Calculating FN1 Force Fit with Purchase Part.mp4
051-GD&T Choosing Datums II.mp4
052-Applying GD&T 3 Basic Steps.mp4
053-GD&T Lesson 6 Profile Tolerances.mp4
054-GD&T Projected Tolerance Zone.mp4
055-Closing Skills Gap HVCC's Metrology Training Program with ZEISS CMMs.mp4
056-GD&T Senior Certification Exam What to Expect and Basic Strategy.mp4
057-GD&T Q&A Counterbore Datum Feature & Composite Position CNC.mp4
058-GD&T Simultaneous & Separate Requirements.mp4
059-GD&T Inner & Outer Boundaries, Virtual & Resultant Conditions.mp4
060-Tolerance Stackup Vector Method with GD&T.mp4
061-GD&T Calculating Max Axis Separation, Coaxial Features, RMB & MMB (Calculating Datum Shift).mp4
062-GD&T Lesson 7 Position Tolerance.mp4
063-Complaining about ASME Y14.5 Changes 1994-2009.mp4
064-Cheap Books for GD&T.mp4
065-GD&T Details "Nonrigid" Part, Exception to Rule 1.mp4
066-GD&T Composite Profile With Individually.mp4
067-ASME Y14.45 Reporting Basic Dimensions.mp4
068-GD&T Composite Profile Inspection Demonstration.mp4
069-ASME Y14.5 GD&T Surface vs Axis Method Explanation.mp4
070-GD&T Q&A Composite Position with Different Material Conditions.mp4
071-GD&T Relative Shift Multiple Datum Reference Frames.mp4
072-GD&T Free State Symbol.mp4
073-GD&T Common Datum Feature "A-B".mp4
074-GD&T Common Datums Part 2, Continuous Feature, Position, Runout.mp4
075-GD&T Application Live Stream.mp4
076-GD&T Livestream 2.mp4
077-GD&T Livestream #3 "Going over my drawings from college".mp4
078-GD&T Livestream 4 "Drawing Review, Datum Targets".mp4
079-GD&T Livestream #6.mp4
080-GD&T Plus-Minus to Position.mp4
081-GD&T Converting Bolt Holt Circles to Position.mp4
082-GD&T Livestream #7.mp4
083-GD&T Most Important Symbol Explained.mp4
084-GD&T Livestream #8.mp4
085-Can a Derived Median Line be a Datum GD&T.mp4
086-GD&T Livestream #9.mp4
087-GD&T Live #11 Composite Postion.mp4
088-GD&T Livestream #14.mp4
