How To Grind A Hss Turning Tool
I'd add that if the wheel comes apart, an apron isn't going to do anything to protect you.
Not a whole heck of a lot is going to protect you if the wheel comes apart.. I've tended to make a bit of a habit to stand just off to the side of the wheel. especially on the wire wheel. those little curly spears are deadly.
Oz,
I have developed a tendency to wear gloves more often for many things but certainly not bulky gloves when it is known to be a hazard. On the question of wearing gloves (or not) while grinding is there any allowance to be made for belt grinders versus wheel grinders?
Also, does it depend on the style of glove? I wear blue nitrile gloves almost always when in my shop and don't see any danger to it. It is great to have the grip they provide for many operations, grinding included.
PS Had not read Mikey's post when typing this.
Mikey,
Can I send you all of my HSS and let you sharpen it for me? :D
Just kidding. Nice post there, especially the shots of each grind. Pictures say a lot. I look at more pictures than reading!
Ken
I guess I'm not
Sorry Mikey but I am just answering in rebuttal to what seems as anti carbide/misinformation on threads I read ...
...and I also agree and like to see the grinding (sharpening) skill of cutters going onward;
...Sharpening carbide also does just that (Again; I'm not talking about insert tooling in the home, hobby setting (But grabbing a handful from a bucket of dull or chipped throw aways can also be silver soldered to prehard or boring bars and sharpened...(and IMO; My take (experience) with carbide is also good for the beginner/novice and home machinist to know and consider...
...Again and granted; A diamond wheel (I prefer a 220 "face wheel") is the way to sharpen carbide (with a coarser (around 100) diamond wheel on a regular old 8" "snag grinder is the way to rough form one (if needed)...
...But then, with all the same info around here (for instance like you have also posted) on HSS cutter angles and experimentation as applied to different materials, one ends up with a superior cutter (many times longer lasting edge) for most materials (steels,...especially the tool steels) on any lathe (that isn't "slop city" lol)...
....Again; Some carbides aren't much better(**) for wear than HSS and some it behooves one to put a little more nose radius (chipping) for heavy and interupted cuts...
....(**)= again depending on grades (thangs' such as cobalt content, grain size, tonnage of press, hot (or not lol) isostatically pressed...and yada yada
...so with all that, I'll post this link again and notice the braised carbide cutter pics and illustrations (ground forms and angles) are very much the same as HSS:
https://www.google.com/search?q=car...X&ved=0ahUKEwjyqf3oydTQAhWhxVQKHZIDAyIQsAQIGg
Chris, my intent was to help a new guy learn to grind a good tool, that's all. As near as I can tell, I provided no misinformation. Instead, I tried to provide information as simply and accurately as I could.
If you're somehow construing that this post is a debate that somehow warranted a "rebuttal" from you, tell me what I said that justified such a vigorous response from you. Maybe instead of pushing your own agenda here, why not start a new thread that states your position and then teach the guys how to do what you think they should do? I may not agree with your views but I'll be damned if I don't respect your right to have them. And as I said before, I will not come into your thread and disrespect you.
I am not a pro machinist like you. I am a lowly hobby guy with only 25 years messing with metal so I'm still learning every day. I am also a Professional in my own field, with over 35 years of experience. In my world, professional conduct is somewhat different.
Mikey, I in no way think of anybody here as lowly....also I am not pushing my own or any agenda (In this subject case: Carbide as compared to HSS cutters)...
...But to answer how/and what that I construed a rebuttal (Which IMO is not so vigorous (I'm just also trying to teach and yes, no matter what experience we have, we all learn if we're open to it)...anyway, it is from a snippet from your subject somewhere above: "Most of us don't own big, rigid, fast or powerful lathes. We own hobby lathes, typically in the 10-11" class with max speeds of 2500 rpm or so. For those lathes and smaller, HSS is usually the best tooling option......"
...I guess so as not go round and round with examples and facts on your take again that carbide needs big, rigid, fast and powerful lathes that run more than 2500 RPM I will use your own words in previous threads: "We should agree to disagree"... (But note: I don't think I have ever ran a manual machine spindle at more than 2000 rpm except for high speed polishing and maybe for double o and triple 0 center drills, tiny drills and even then 1000 to 2000 depending on yada is norm)
...and again; My garage Logan, or the Machinists "old" 9" to 12" lathe area in our shop (Lablonde, Logan, Southbend and a pretty weak newer Clausing), although well kept, were anything but big, rigid, fast and powerful...
...I also think, in regards to your dis on my professionalism above, I thinks' (Hey" I heard that!), maybe (probably) it's a difference in perception plus what environment each of us has worked in for decades, as in my world one cannot help but develop layers of thick skin on the shop floor...
...also please note that every comment I have given you respect by way of saying: "with all due respect but I disagree"...and, like on your subject title here: " Great posts and step by step Mikey except...." And note that my disagreements (just carbide details and applications so far) are just that and usually include a "smiley face here"
...also I'm the 1st one to admit while using "production value" as the buzz words I've seen here on this site regarding authoring my own subject titles;
I would/am in last place as my only equipment in that regard is my "specs" and this laptop I'm pecking on now (again, even my phone is a $39.95 flip phone LOL)...
...so I'll just leave all the great "threads", questions, with pictures and videos to others and my silence usually means I'm learning or agree but when I see or read a detail that is off kilter I will respond with my opinion (and yes when the "off kilter" is somewhat repetitive, my response may include a "BS" (but followed with a "Smiley face here!")
...Maybe I need to work on my professionalism and friendliness and just read (unless I see or read something dangerous).... I'm sure all will get along fine without my input)
https://www.linkedin.com/in/christian-poulsen-49b05b30?trk=nav_responsive_tab_profile
Mikey,
Ken
Thanks, Ken. Coming from you, that's high praise.
Chris, as tempting as it is to respond to you honestly, I won't do that. Instead, I want to steer the discussion back to the subject at hand so that the new guys can ask questions and/or discuss their concerns. This thread is about how to grind a tool and to help those who wish it. This is about them. If you want to help them or if you have something to contribute to that subject then feel free to join the discussion. I, for one, would like to see what your HSS tools look like.
On the other hand, if you want to show us how to grind carbide tools then start a thread and show us how to do it. I'm willing to learn and I'm sure there are others here who would, too.
What's the speed of that belt sander you have?
I modified a 4x36" woodworking sander (just moved the table from the disc to the belt) set to 15°.
Also, what belts do you use? I tried a home depot special, Diablo belt, says good for wood, metal, plastic. got about 5 minutes and that one tool bit out of it. now it's dull. lol
If the tool works then it works - good for you! As you get used to the process things will be easier to control - it looks like you're most of the way there already. I can see side rake, back rake, good relief angles and enough of an end cutting edge angle to access shoulders. Nose radius looks to be about 1/64" and that will work great. Pretty tools are great and will come with practice but function is what counts and you've got that now - way to go!
My belt sander runs at 3450 rpm. I get my Aluminum Oxide belts from an ebay seller called Barbkat. Most sanding belts have a shelf life of about a year so buy only what you can use quickly. If the belts get old the adhesive in the splice gives out and the belts can snap. I usually buy 5 belts of 24 grit to shape and 80 grit to fine sand the bit and then hone from there. I try to make tools in batches and grind up a bunch to use the belts while the splice is strong. Last time I ground tools I think I made 10 of them. Then I don't buy belts until I need to grind again.
I also use a wax stick lubricant, applying some to the running belt for about 2 seconds. This is enough to cut cool and fast. I apply some before grinding each face. You can find this stuff on Amazon or from industrial suppliers.
https://www.amazon.com/C-R-Laurence...480724066&sr=8-2&keywords=wax+stick+lubricant
One tube will last me over 10 years so its pretty cheap if you amortize it over time.
I have nothing to add but a thank you. I recently bought (5) 3/8" HSS blanks to get started on. I've tried some carbide and it worked ok but not a very good finish. I'm very new at this and like to run the lathe as slow as possible until I get a better feel for it. It had one HSS bit when I got it. I used it a few times and got a nice finish and then switched to carbide and could cut deeper but the finish wasn't as good. I feel like rpm is the main reason for that. I havea 6" and 8" bench grinders. I'm making some nice tool rests for the 6" and plan to use it for nothing but sharpening.
Your pics and descriptions were good. I really appreciate you sharing your time on this. That's why I like this place so much.
