Maybe a little late on this response. I'm in the process of installing my Igaging DROs on my 12x30 lathe. The L feed is getting mounted on the backside of the bed. Since theres no lead screws or anything else on that side. It'll be pretty well protected back there too. The x feed is getting mounted onto the right side of the cross feed, since that side sees less swarf. It's gonna stick up a little bit, but not enough to interfere with anything. I'm gonna use 3M VHB mounting tape to mount them.
http://solutions.3m.com/wps/portal/...R8gs_QNRM99KDQB_N2RL3FHWVK_GPD0K8BC31gv)&rt=d
People are mounting gear racks for x-y tables with this stuff, so, I'm gonna give it a shot. The area has to be degreased really well and then followed up by isopropyl alcohol. I had some that I used for mounting other things around the shop and it's fantastic stuff. I just hope that there's enough surface area on the brackets for it to bond. If it works and stays, you guys will know about it. If it fails, I'll just drill and tap like every one else. :whistle:
I'll post up pictures when I'm done
