- Nov 17, 2017
- 1,525
At 1.5" in diameter in 1/4 mild steel you really don't want more than 50-70 RPMs unless you have flood coolant.
In addition you will want to have a hole larger than the central web between the cutting edges of the final sized drill. This central web only displaces material so the cutting edge can remove it. Once the web is dull, it does not mater how sharp the cutting edge is.
