- Feb 2, 2013
- 3,644
With the use of spdt swich, you can make it a 2 speed motor
That is cooler motor .I have the motor show in the attachment on a South Bend 9 with flat belt drive cone pulleys. For Rpm, the motor is labeled "1725/1140". I did a calculation on the current set-up based on 1725 Rpm which if my calculations are correct(?) I come up with the slowest spindle speed of about 415 rpm. The countershaft drive pulley has 2 steps, and it is on the smaller step. The motor drive pulley is 3" diameter.
If the motor is running at 1140 rpm, I think I would come up with a spindle rpm of about 274, again, if my calculations are correct (?).
How do I tell if the motor is set up to run at 1725 or 1140 rpm; and if at 1725, how would I reduce it to 1140 rpm? Also, would there be any issue in running it at 1140?
I've had one of these for a couple of years. I only use it every few months, but it does the job.I need to invest in a tach.
Thanks. Ordered it. Had to add to cart to get free shipping, and I ordered these machine lights again. They work great.I've had one of these for a couple of years. I only use it every few months, but it does the job.
I have a couple of those lights, and I agree that they are really useful. For the tach: I didn't find that the adhesive on the included reflective tape was very useful. I had some SOLAS reflective tape (marine version of truck reflector tape) and a small piece of that worked well. If the rotating surface is reflective (like the mill quill) I just wrap black electrical tape around and then cut a 'slot' in the tape to leave a reflective area.Thanks. Ordered it. Had to add to cart to get free shipping, and I ordered these machine lights again. They work great.
I wanted this lower speed range because the South Bend book, How to Run a Lathe, states in a footnote that "When using high countershaft speed, back gears should not be engaged."
Again, I don't know which rpm the motor is set at; so, I cant' determine spindle speed. However, at least the spindle speed is now in the lower range due to the pulley change. I need to invest in a tach.
Now I need to search whether the speed ranges listed by South Bend are based on a 2" motor pulley.
