- Dec 18, 2019
- 7,382
I made an attempt to single point an acme screw (nominally 3/4-5) and it didn't quite come out right. The tool was ground from a 3/8" HSS blank. It's 5 TPI, but the cut thread seems wider than it should be. The pitch is correct. I do know that I didn't make an attempt to compensate for the lead angle.
What I don't understand is the relationship of the lead angle to the shim angle. (I think this is the amount that the tool is rotated to become more aligned with the lead angle.) My Aloris AXA-8 HSS threading tool has a means to make this adjustment, but I don't have acme blades. Not sure I'd want to buy an acme blade right now, as this is most likely a one or two of build. (5 TPI acme blade = $67 from Aloris, which isn't bad, if I was doing this a lot. But this is good for one pitch only.)
Can someone enlighten me on the subject? Or point me to a source that might show pictures and math? Don't want a "calculator" since I'd like to know what it means geometrically first. I haven't yet found a good explanation. Is it just set to the lead angle?
