- Jan 25, 2015
- 2,558
First off, I’m still a novice so this is probably my inexperience showing.
I need to make a bit of an odd shaped piece.
Basically, its square edged on one end and rounded on the other.
can’t do it on the lathe, that would just make the whole piece round.
Tried to mount it to my little 3” rotary table but when touched to the side mill…well, lets just say it didn’t work out well. Too much lash in the table screw and if I tigthen it up, it jams the table and eventually the milling cutter grabbed the stock so hard it jammed the table hard. I had to take the rotary table completely apart to get it freed up again.
CNC would be nice, but that waaay outside my current budget.
I tried using the xy wheels to make a circle, but I was never any good with an “etch a sketch” for anything besides straight lines, so you can probably guess how that went.
So I’m stuck. I Just can’t figure out how to mill this piece. I know it can be done, guys make far more complex shapes than this on manual mills.
Any ideas?
Any ideas?
