I usually use the score and snap method, but I deleted my prior post recommending that method when I saw it was discs you needed. Score and snap doesnt work well on discs unless you down mind sanding them to shape from a rough cut. Tom is right, the tool will "weld" to the material. That is why you should try to cut the sheet into manageable pieces and clamp them to the drill press table when using the circle cutter. If it grabs, the spindle will stick and the chuck might come loose from its taper and that's it. Never work with the workpiece loose because when the tool grips it, it will get tossed back at you- fast.
