I've settled on a few tricks that might help.
- try to converge on the target bore by the same increment, say 0.005" per pass. Some materials are not as forgiving for sneaking up on a dimension, especially if they work harden or don't play as well with the cutter type/nose geometry/rigidity.... So for example 0.005 + 0.005 + 0.005" (measuring in between of course) might get you to closer to the target than 0.010 + 0.003 + 0.002
- make the boring bar spring passes at different feed rates on your lathe. It does make a difference because you are changing the traversing pitch, so stand a better chance of cutting off the hilltops vs. the tool following along in the same path like a record player. So my ritual is 3 identical spring passes with carriage locked at the 3 finest feeds on my lathe.
- use the heaviest most rigid boring bar with shortest stick-out. Listen/feel for any harmonics, adjust rpm/feed accordingly
- make sure your carriage is locked every pass & ideally using something like a DRO. Even the act of locking the carriage can be enough to move it slightly (+/- 0.002" is not uncommon) depending on your lathe wear & how the clamping mechanism imparts itself against the dovetails or whatever. A DRO sees this because its measuring independently whereas a dial machine will not.
- if you can find a reamer to match your bore, it can save a lot of work. Now boring means just getting it appropriately undersize so the reamer can do its job with more consistency. Ensure your tailstock is very well centered.
- assuming you are not into toolpost grinding, that then leaves lapping. Its best to use the correct tools & the don't have to be expensive. These brass laps work well & are reasonable. Ideally you want a softer material (brass or some folks use copper for home made ones) which will embed the grit. This is somewhat messy & time consuming work. I would recommend not being much more that 0.002" undersize because it takes a lot of lapping to get that final amount down. http://www.acrolaps.com/
